Grafana variable conversion from float format to Integer
I am trying to convert the variable type from float format to original without decimal format by using Prometheus, but can’t find the reference example of my requirement. Anyone have any suggestion to display.
Current format
9.3739053e+07
Expected to display
93739053
where are you trying to convert the value? Can you share a screenshot?
In the variable section
Hi Matt,
I have shared screenshots, could you pls help on my request ?
