Graph Panel: Coloring the Left and Right Y-axes
I am trying to create a plugin based on the Graph Panel.
I would like to ask if it is possible to color the ticks of the Left and Right Y-Axes, or if it would possible to color the entire Y-Axes.
For example, is there a way to color the ticks of the Y-Axes based on the color each metric is using:
Any hep would be appreciated! Thank you in advance!
@mefraimsson @torkel @daniellee
Note sure if that’s supported by flot, you can have a look in the code and see if it’s supported. The graph panel are using flot to render its graph.
@mefraimsson
I will have a look at the code.
Thank you, I appreciate it!
