Graph panel showing date axis X, and Number axis Y
Hi, I’m trying to configure a panel showing two data:
  • Date
  • Qty (number)
    Following i attach an image showing the query and the result set: 2 columns (date and qty)
    This 2 values i’d like to show on a panel like graph, so i can see the qty for each date.
    I can make it work, it just shows empty.
    I also attach an image from grafana configuration panel.
    Thanks!
Welcome to the Grafana forum.
It appears you are using SQL Server as your datasource? Below your query in Grafana, is there a dropdown box where you set the format as Time Series? If yes, then the query must have a column named time (not date). More info here.
