I have a Graph Panel with Values stacking.
It seems that if some value not exists in one bar, it is copied from last bar where it has a value.
What expected (pay attention to orange State 5):
What Grafana shows overall and what Grafana shows if I filter State 5 (it correctly shows State 5 bars, but in tooltips still ghost values):.
May be it some how should be releated to Null value option.
But graph looks the same with any Null value options.
And I should note that there is no nulls in data, it just have no value at all and it will be difficult to add there null or 0 since it is GROUP BY that counts events with particular state. No events - no record.
Please help to fix it!
Below is the panel settings and the sample data:
"aliasColors": {},
"bars": true,
"dashLength": 10,
"dashes": false,
"datasource": "MyDB",
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 9,
"w": 12,
"x": 0,
"y": 0
"id": 2,
"legend": {
"avg": false,
"current": false,
"max": false,
"min": false,
"show": true,
"total": false,
"values": false
"lines": false,
"linewidth": 1,
"nullPointMode": "null",
"options": {
"dataLinks": []
"percentage": false,
"pointradius": 2,
"points": false,
"renderer": "flot",
"seriesOverrides": [],
"spaceLength": 10,
"stack": true,
"steppedLine": false,
"targets": [
"alias": "",
"format": "time_series",
"hide": false,
"rawSql": "SELECT Time as time, Value as value, Metric as metric FROM _Temp ORDER BY Time ASC",
"refId": "A"
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "Panel Title",
"tooltip": {
"shared": true,
"sort": 1,
"value_type": "individual"
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
CREATE TABLE [dbo].[_Temp]( [Time] [int] NOT NULL, [Metric] [nvarchar](max) NOT NULL, [Value] [int] NOT NULL)
GO
INSERT INTO [_Temp] ([Time],[Value],[Metric] ) VALUES
(1566201600, 11, N'State 1'),
(1566205200, 18, N'State 1'),
(1566208800, 10, N'State 1'),
(1566212400, 1, N'State 5'),
(1566212400, 26, N'State 1'),
(1566216000, 16, N'State 1'),
(1566219600, 11, N'State 1'),
(1566223200, 15, N'State 1'),
(1566226800, 14, N'State 1'),
(1566230400, 1, N'State 5'),
(1566230400, 11, N'State 1'),
(1566234000, 15, N'State 1'),
(1566237600, 16, N'State 1'),
(1566241200, 15, N'State 1'),
(1566244800, 4, N'State 5'),
(1566244800, 13, N'State 1'),
(1566248400, 14, N'State 1'),
(1566252000, 14, N'State 1'),
(1566255600, 13, N'State 1'),
(1566259200, 6, N'State 5'),
(1566259200, 15, N'State 1'),
(1566262800, 11, N'State 1'),
(1566266400, 13, N'State 1'),
(1566270000, 16, N'State 1'),
(1566273600, 1, N'State 5'),
(1566273600, 12, N'State 1'),
(1566277200, 1, N'State 5'),
(1566277200, 17, N'State 1'),
(1566280800, 13, N'State 1'),
(1566284400, 2, N'State 5'),
(1566284400, 13, N'State 1'),
(1566288000, 1, N'State 5'),
(1566288000, 8, N'State 1')
