9.0.2, Mac -
Format the data in a column using valuemap then use groupBy transformation for the pie chart -
I applied two value mappings for the exceptionMessage column. Then, I added 2 transformations. Add Field From Calculation transformation to add the count field and Group by transformation to group by the exceptionMessage.
What happened?
For some reason, the same value doesn’t get merged. -
I expect the same value gets merged and shows the proper accumulated count -
Did you follow any online instructions? If so, what is the URL?
For some reason my rename by regex did not work but value mapping worked. Now the issue that I am having is that I cannot group by a value mapping. Any suggestions?
