Grafana Cloud 9.0.5 -
Create a bar chart that shows # request per path, grouped by parent path, based on the access logs of an nginx container. -
A query in Grafana, based on a Loki data source. -
What happened?
I don’t know how to write this query. -
The results are grouped by parent path. For example/path/subpath
and/path/othersubpath
are grouped under/path
For example, given these fake logs:
GET /foo/bar
GET /foo/baz
GET /quux/
GET /foo
GET /baz
I would expect to get a table like the following:
/foo 3
/quux 1
/baz 1
- Can you copy/paste the configuration(s) that you are having problems with?
Query:
sum by(path)
(count_over_time(
{compose_project="deployment"}
| pattern `<_> - - <_> "<method> <path> <_>" <status> <_> <_> "<_>" <_>`
| path!=`` [$__range]))
One thing I did try was creating a column for each label of each series. This results in each row having a column that contains its path. If all I could do now was calculate a column that calculates the parent path with a regex or something, I’d be set.
