Hello
I am deploying a loki in HA with currently two nodes (without Kubernetes).
Overall it works fine.
However, when I make requests to find logs, the number of logs returned differs half the time.
For example, query 1 on a fixed range hits instance 1 and returns me 430 records.
I relaunch the same query which hits instance 2 and returns 230 records this time.
Being in the migration phase, I have another loki (non HA) somewhere else that receives the same traffic as my new HA loki.
When I make this same request, I receive 660 records, the sum of the two previous requests (230 + 430) on the loki HA!
Do you have any idea what could be happening?
For information:
- I use a s3 bucket to store indexes
- Each loki instance is running in target=all
- Each Loki instance is contacted through an nginx reverse proxy
- I have upstream of each reverse proxy, a load balancer provided by my cloud provider which returns in round robin to my nginx servers
Thx for your help !!
My config:
target: all
http_prefix: ""
ballast_bytes: 0
use_buffered_logger: true
use_sync_logger: true
server:
http_listen_network: tcp
http_listen_address: ""
http_listen_port: 3100
http_listen_conn_limit: 0
grpc_listen_network: tcp
grpc_listen_address: ""
grpc_listen_port: 9095
grpc_listen_conn_limit: 0
tls_cipher_suites: ""
tls_min_version: ""
http_tls_config:
cert_file: ""
key_file: ""
client_auth_type: ""
client_ca_file: ""
grpc_tls_config:
cert_file: ""
key_file: ""
client_ca_file: ""
register_instrumentation: true
graceful_shutdown_timeout: 30s
http_server_read_timeout: 30s
http_server_write_timeout: 30s
http_server_idle_timeout: 2m0s
grpc_server_max_recv_msg_size: 4194304
grpc_server_max_send_msg_size: 4194304
grpc_server_max_concurrent_streams: 100
grpc_server_max_connection_idle: 2562047h47m16.854775807s
grpc_server_max_connection_age: 2562047h47m16.854775807s
grpc_server_max_connection_age_grace: 2562047h47m16.854775807s
grpc_server_keepalive_time: 2h0m0s
grpc_server_keepalive_timeout: 20s
grpc_server_min_time_between_pings: 10s
grpc_server_ping_without_stream_allowed: true
log_format: logfmt
log_level: error
log_source_ips_enabled: false
log_source_ips_header: ""
log_source_ips_regex: ""
log_request_at_info_level_enabled: false
http_path_prefix: ""
internal_server:
http_listen_address: localhost
http_listen_port: 3101
grpc_listen_network: ""
grpc_listen_port: 0
tls_min_version: ""
http_tls_config:
cert_file: ""
key_file: ""
client_ca_file: ""
grpc_tls_config:
cert_file: ""
key_file: ""
client_ca_file: ""
register_instrumentation: false
grpc_server_max_recv_msg_size: 0
grpc_server_max_send_msg_size: 0
grpc_server_max_concurrent_streams: 0
grpc_server_max_connection_idle: 0s
grpc_server_max_connection_age: 0s
grpc_server_max_connection_age_grace: 0s
grpc_server_keepalive_time: 0s
grpc_server_keepalive_timeout: 0s
grpc_server_min_time_between_pings: 0s
grpc_server_ping_without_stream_allowed: false
log_format: ""
log_level: ""
enable: false
distributor:
ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
host: localhost:8500
acl_token: ""
http_client_timeout: 20s
consistent_reads: false
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_insecure_skip_verify: false
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_enabled: false
mirror_timeout: 2s
heartbeat_period: 15s
heartbeat_timeout: 1m0s
instance_id: loki-instance-0
instance_interface_names:
- ens2
- ens4
- docker0
- br-a369ef4d6f79
- lo
instance_port: 0
instance_addr: 127.0.0.1
rate_store:
max_request_parallelism: 200
stream_rate_update_interval: 1s
ingester_request_timeout: 500ms
querier:
tail_max_duration: 1h0m0s
query_ingesters_within: 3h0m0s
engine:
timeout: 5m0s
max_look_back_period: 30s
max_concurrent: 10
query_store_only: false
query_ingester_only: false
multi_tenant_queries_enabled: false
query_timeout: 0s
per_request_limits_enabled: false
query_scheduler:
max_outstanding_requests_per_tenant: 4096
querier_forget_delay: 0s
grpc_client_config:
max_recv_msg_size: 104857600
max_send_msg_size: 104857600
grpc_compression: ""
rate_limit: 0
rate_limit_burst: 0
backoff_on_ratelimits: false
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
use_scheduler_ring: true
scheduler_ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
tokens_file_path: ""
zone_awareness_enabled: false
- ens2
- ens4
- docker0
- br-a369ef4d6f79
- lo
instance_port: 0
instance_availability_zone: ""
frontend:
log_queries_longer_than: 5s
max_body_size: 10485760
query_stats_enabled: false
max_outstanding_per_tenant: 4096
scheduler_address: ""
scheduler_dns_lookup_period: 10s
scheduler_worker_concurrency: 5
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
graceful_shutdown_timeout: 5m0s
- ens2
- ens4
- docker0
- br-a369ef4d6f79
- lo
address: ""
port: 0
compress_responses: true
downstream_url: ""
tail_proxy_url: ""
tail_tls_config:
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
query_range:
split_queries_by_interval: 0s
align_queries_with_step: true
results_cache:
cache:
enable_fifocache: false
default_validity: 1h0m0s
background:
writeback_goroutines: 10
writeback_buffer: 10000
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
update_interval: 1m0s
consistent_hash: true
circuit_breaker_consecutive_failures: 10
circuit_breaker_timeout: 10s
circuit_breaker_interval: 10s
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
enabled: true
max_size_mb: 100
ttl: 24h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: frontend.
async_cache_write_back_concurrency: 16
async_cache_write_back_buffer_size: 500
compression: ""
cache_results: true
max_retries: 5
parallelise_shardable_queries: false
forward_headers_list: []
ruler:
external_url: ""
ruler_client:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
evaluation_interval: 1m0s
poll_interval: 1m0s
storage:
type: ""
azure:
environment: AzureGlobal
account_name: ""
account_key: ""
container_name: loki
endpoint_suffix: ""
use_managed_identity: false
use_federated_token: false
user_assigned_id: ""
use_service_principal: false
client_id: ""
client_secret: ""
tenant_id: ""
chunk_delimiter: '-'
download_buffer_size: 512000
upload_buffer_size: 256000
upload_buffer_count: 1
request_timeout: 30s
max_retries: 5
min_retry_delay: 10ms
max_retry_delay: 500ms
alibabacloud:
bucket: ""
endpoint: ""
access_key_id: ""
secret_access_key: ""
gcs:
bucket_name: ""
service_account: ""
chunk_buffer_size: 0
request_timeout: 0s
enable_opencensus: true
enable_http2: true
s3:
s3: ""
s3forcepathstyle: false
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
session_token: ""
insecure: false
sse_encryption: false
http_config:
idle_conn_timeout: 1m30s
response_header_timeout: 0s
ca_file: ""
signature_version: v4
storage_class: STANDARD
sse:
type: ""
kms_key_id: ""
kms_encryption_context: ""
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
bos:
bucket_name: ""
endpoint: bj.bcebos.com
access_key_id: ""
swift:
auth_version: 0
auth_url: ""
internal: false
username: ""
user_domain_name: ""
user_domain_id: ""
user_id: ""
password: ""
domain_id: ""
domain_name: ""
project_id: ""
project_name: ""
project_domain_id: ""
project_domain_name: ""
region_name: ""
container_name: ""
max_retries: 3
connect_timeout: 10s
request_timeout: 5s
local:
directory: ""
rule_path: /loki/rules-temp
alertmanager_url: ""
enable_alertmanager_discovery: false
alertmanager_refresh_interval: 1m0s
enable_alertmanager_v2: false
notification_queue_capacity: 10000
notification_timeout: 10s
alertmanager_client:
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
basic_auth_username: ""
basic_auth_password: ""
type: Bearer
for_outage_tolerance: 1h0m0s
for_grace_period: 10m0s
resend_delay: 1m0s
enable_sharding: false
sharding_strategy: default
sharding_algo: by-group
search_pending_for: 5m0s
ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
- ens2
- ens4
- docker0
- br-a369ef4d6f79
- lo
instance_port: 0
num_tokens: 128
flush_period: 1m0s
enable_api: true
enabled_tenants: ""
disabled_tenants: ""
disable_rule_group_label: false
wal:
tenant: ""
remotewrite: []
dir: ruler-wal
truncate_frequency: 1h0m0s
min_age: 5m0s
max_age: 4h0m0s
wal_cleaner:
min_age: 12h0m0s
deprecatedperiod: 0s
remote_write:
enabled: false
config_refresh_period: 10s
ingester_client:
pool_config:
client_cleanup_period: 15s
health_check_ingesters: true
remote_timeout: 1s
remote_timeout: 5s
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
ingester:
lifecycler:
ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
replication_factor: 1
excluded_zones: ""
num_tokens: 128
observe_period: 0s
join_after: 0s
min_ready_duration: 15s
interface_names:
- ens2
- ens4
- docker0
- br-a369ef4d6f79
- lo
final_sleep: 0s
unregister_on_shutdown: true
readiness_check_ring_health: true
address: 127.0.0.1
port: 0
concurrent_flushes: 32
flush_check_period: 30s
flush_op_timeout: 10m0s
chunk_retain_period: 1m0s
chunk_idle_period: 30m0s
chunk_block_size: 262144
chunk_target_size: 1572864
chunk_encoding: snappy
max_chunk_age: 2h0m0s
autoforget_unhealthy: false
sync_period: 0s
sync_min_utilization: 0
max_returned_stream_errors: 10
query_store_max_look_back_period: 2h41m0s
wal:
enabled: true
dir: /loki/wal
checkpoint_duration: 5m0s
flush_on_shutdown: false
replay_memory_ceiling: 4294967296
index_shards: 32
max_dropped_streams: 10
index_gateway:
mode: simple
ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
- ens2
- ens4
- docker0
- br-a369ef4d6f79
- lo
instance_port: 0
storage_config:
alibabacloud:
bucket: ""
endpoint: ""
access_key_id: ""
aws:
dynamodb:
dynamodb_url: ""
api_limit: 2
throttle_limit: 10
metrics:
url: ""
target_queue_length: 100000
scale_up_factor: 1.3
ignore_throttle_below: 1
queue_length_query: sum(avg_over_time(cortex_ingester_flush_queue_length{job="cortex/ingester"}[2m]))
write_throttle_query: sum(rate(cortex_dynamo_throttled_total{operation="DynamoDB.BatchWriteItem"}[1m]))
by (table) > 0
write_usage_query: sum(rate(cortex_dynamo_consumed_capacity_total{operation="DynamoDB.BatchWriteItem"}[15m]))
by (table) > 0
read_usage_query: sum(rate(cortex_dynamo_consumed_capacity_total{operation="DynamoDB.QueryPages"}[1h]))
by (table) > 0
read_error_query: sum(increase(cortex_dynamo_failures_total{operation="DynamoDB.QueryPages",error="ProvisionedThroughputExceededException"}[1m]))
by (table) > 0
chunk_gang_size: 10
chunk_get_max_parallelism: 32
backoff_config:
min_period: 100ms
max_period: 50s
max_retries: 20
kms_key_id: ""
s3: s3://######":######@s3.fr-par.wwwww.cloud/my-storage
s3forcepathstyle: true
bucketnames: ""
endpoint: ""
region: fr-par
access_key_id: ""
session_token: ""
insecure: false
http_config:
ca_file: ""
sse:
type: ""
kms_key_id: ""
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
azure:
account_name: ""
account_key: ""
endpoint_suffix: ""
client_id: ""
client_secret: ""
tenant_id: ""
max_retries: 5
bos:
bucket_name: ""
access_key_id: ""
bigtable:
project: ""
instance: ""
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: true
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
table_cache_enabled: true
table_cache_expiration: 30m0s
gcs:
bucket_name: ""
service_account: ""
request_timeout: 0s
enable_http2: true
cassandra:
addresses: ""
port: 9042
keyspace: ""
consistency: QUORUM
replication_factor: 3
disable_initial_host_lookup: false
SSL: false
host_verification: true
host_selection_policy: round-robin
CA_path: ""
tls_cert_path: ""
tls_key_path: ""
auth: false
username: ""
password: ""
password_file: ""
custom_authenticators: []
timeout: 2s
connect_timeout: 5s
reconnect_interval: 1s
max_retries: 0
retry_max_backoff: 10s
retry_min_backoff: 100ms
query_concurrency: 0
num_connections: 2
convict_hosts_on_failure: true
table_options: ""
boltdb:
directory: ""
filesystem:
directory: ""
swift:
auth_version: 0
auth_url: ""
internal: false
username: ""
user_domain_id: ""
user_id: ""
password: ""
domain_id: ""
domain_name: ""
project_id: ""
project_name: ""
region_name: ""
container_name: ""
max_retries: 3
request_timeout: 5s
grpc_store: {}
hedging:
at: 0s
up_to: 2
max_per_second: 5
named_stores:
aws: {}
azure: {}
bos: {}
filesystem: {}
gcs: {}
alibabacloud: {}
swift: {}
index_cache_validity: 5m0s
index_queries_cache_config:
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: store.index-cache-read.
disable_broad_index_queries: false
max_parallel_get_chunk: 150
max_chunk_batch_size: 50
boltdb_shipper:
active_index_directory: /loki/index
shared_store: s3
shared_store_key_prefix: index/
cache_location: /loki/boltdb-cache
cache_ttl: 24h0m0s
resync_interval: 5m0s
query_ready_num_days: 0
index_gateway_client:
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
log_gateway_requests: false
use_boltdb_shipper_as_backup: false
ingestername: loki-instance-0
mode: RW
ingesterdbretainperiod: 20m0s
build_per_tenant_index: false
tsdb_shipper:
active_index_directory: ""
shared_store: ""
cache_location: ""
cache_ttl: 24h0m0s
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
mode: RW
chunk_store_config:
chunk_cache_config:
enable_fifocache: true
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: store.chunks-cache.
write_dedupe_cache_config:
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: store.index-cache-write.
cache_lookups_older_than: 0s
max_look_back_period: 31d
schema_config:
configs:
store: boltdb-shipper
object_store: s3
schema: v11
index:
prefix: loki_index_
period: 1d
tags: {}
chunks:
prefix: ""
period: 0s
tags: {}
row_shards: 16
compactor:
working_directory: /loki/compactor
shared_store: s3
compaction_interval: 5m0s
apply_retention_interval: 0s
retention_enabled: true
retention_delete_delay: 2h0m0s
retention_delete_worker_count: 150
retention_table_timeout: 0s
delete_batch_size: 70
delete_request_cancel_period: 24h0m0s
delete_max_interval: 0s
max_compaction_parallelism: 1
upload_parallelism: 10
compactor_ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
- ens2
- ens4
- docker0
- br-a369ef4d6f79
- lo
instance_port: 0
_: false
tables_to_compact: 0
skip_latest_n_tables: 0
deletion_mode: ""
compactor_grpc_client:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
limits_config:
ingestion_rate_strategy: global
ingestion_rate_mb: 4
ingestion_burst_size_mb: 6
max_label_name_length: 1024
max_label_value_length: 2048
max_label_names_per_series: 30
reject_old_samples: true
reject_old_samples_max_age: 1w
creation_grace_period: 10m
enforce_metric_name: false
max_line_size: 0
max_line_size_truncate: false
increment_duplicate_timestamp: false
max_streams_per_user: 0
max_global_streams_per_user: 5000
unordered_writes: true
per_stream_rate_limit: 3145728
per_stream_rate_limit_burst: 15728640
max_chunks_per_query: 2000000
max_query_series: 500
max_query_lookback: 31d
max_query_length: 30d1h
max_query_parallelism: 32
tsdb_max_query_parallelism: 512
cardinality_limit: 100000
max_streams_matchers_per_query: 1000
max_concurrent_tail_requests: 10
max_entries_limit_per_query: 5000
max_cache_freshness_per_query: 10m
max_queriers_per_tenant: 0
query_ready_index_num_days: 0
query_timeout: 5m
min_sharding_lookback: 0s
ruler_evaluation_delay_duration: 0s
ruler_max_rules_per_rule_group: 0
ruler_max_rule_groups_per_tenant: 0
ruler_alertmanager_config: null
ruler_tenant_shard_size: 0
ruler_remote_write_disabled: false
ruler_remote_write_url: ""
ruler_remote_write_timeout: 0s
ruler_remote_write_headers: {}
ruler_remote_write_queue_capacity: 0
ruler_remote_write_queue_min_shards: 0
ruler_remote_write_queue_max_shards: 0
ruler_remote_write_queue_max_samples_per_send: 0
ruler_remote_write_queue_batch_send_deadline: 0s
ruler_remote_write_queue_min_backoff: 0s
ruler_remote_write_queue_max_backoff: 0s
ruler_remote_write_queue_retry_on_ratelimit: false
ruler_remote_write_sigv4_config: null
deletion_mode: filter-and-delete
retention_period: 31d
per_tenant_override_config: ""
per_tenant_override_period: 10s
allow_deletes: false
shard_streams:
enabled: false
logging_enabled: false
desired_rate: 3145728
frontend_worker:
frontend_address: ""
dns_lookup_duration: 3s
parallelism: 10
match_max_concurrent: true
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
table_manager:
throughput_updates_disabled: false
retention_deletes_enabled: true
poll_interval: 2m0s
creation_grace_period: 10m0s
index_tables_provisioning:
enable_ondemand_throughput_mode: false
provisioned_write_throughput: 1000
provisioned_read_throughput: 300
write_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
read_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
enable_inactive_throughput_on_demand_mode: false
inactive_write_throughput: 1
inactive_read_throughput: 300
inactive_write_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
inactive_read_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
inactive_write_scale_lastn: 4
inactive_read_scale_lastn: 4
chunk_tables_provisioning:
write_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
read_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
memberlist:
node_name: loki-instance-0
randomize_node_name: true
stream_timeout: 10s
retransmit_factor: 4
pull_push_interval: 30s
gossip_interval: 200ms
gossip_nodes: 3
gossip_to_dead_nodes_time: 30s
dead_node_reclaim_time: 0s
compression_enabled: true
advertise_addr: ""
advertise_port: 7946
cluster_label: ""
cluster_label_verification_disabled: false
join_members:
- loki-instance-0
- loki-instance-1
min_join_backoff: 1s
max_join_backoff: 1m0s
max_join_retries: 10
abort_if_cluster_join_fails: false
rejoin_interval: 0s
left_ingesters_timeout: 5m0s
leave_timeout: 20s
message_history_buffer_bytes: 0
bind_addr: []
bind_port: 7946
packet_dial_timeout: 2s
packet_write_timeout: 5s
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
runtime_config:
period: 10s
file: ""
tracing:
enabled: true
analytics:
reporting_enabled: true
legacy_read_target: true
common:
path_prefix: /loki
storage:
s3:
s3: ""
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
session_token: ""
insecure: false
http_config:
ca_file: ""
sse:
type: ""
kms_key_id: ""
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
gcs:
bucket_name: ""
service_account: ""
request_timeout: 0s
enable_http2: true
azure:
account_name: ""
account_key: ""
endpoint_suffix: ""
client_id: ""
client_secret: ""
tenant_id: ""
max_retries: 5
alibabacloud:
bucket: ""
endpoint: ""
access_key_id: ""
bos:
bucket_name: ""
access_key_id: ""
swift:
auth_version: 0
auth_url: ""
internal: false
username: ""
user_domain_id: ""
user_id: ""
password: ""
domain_id: ""
domain_name: ""
project_id: ""
project_name: ""
region_name: ""
container_name: ""
max_retries: 3
request_timeout: 5s
filesystem:
chunks_directory: ""
rules_directory: ""
hedging:
at: 0s
up_to: 2
max_per_second: 5
persist_tokens: false
ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
- ens2
- ens4
- docker0
- br-a369ef4d6f79
- lo
instance_port: 0
- ens2
- ens4
- docker0
- br-a369ef4d6f79
instance_addr: ""
compactor_address: ""
compactor_grpc_address: ""
shutdown_delay: 0s
