Handle empty result set with Stat visualisation
  • Grafana version: 8.3.3
  • Visualization: Stat
  • Data source type & version: Microsoft SQL Server 2019
  • OS Grafana is installed on: Windows
  • User OS & Browser: Edge
I’m using variations of the following query to display the health status of an application. I’m also taking advantage of the time series feature that automatically maps the third parameter (metric) to the name assigned to the second parameter (healthy).
When there is data this mostly works as you can see.
When there is no data both the first and the second parameter are shown.
Ideally I’d like to display the health status of an application with no data as unhealthy.
I get the feeling that I need to implement this another way because if there’s no data Grafana can’t know the name of the metric?
SELECT $__timeEpoch(AUDIT_TIME),
       CAST(HEALTHY AS INT) AS healthy,
       APP_NAME             AS metric
FROM ima.dbo.HEALTH_CHECK_RULE
         INNER JOIN ima.dbo.HEALTH_CHECK_METRIC m ON HEALTH_CHECK_RULE.RULE_ID = m.RULE_ID
WHERE $__timeFilter(AUDIT_TIME)
  AND APP_NAME = 'mwproxy'
  AND RULE_NAME = 'All checks'
ORDER BY AUDIT_TIME ASC
Welcome
Please provide DDL and DML for both tables?
create table #HEALTH_CHECK_RULE --etc
create table #HEALTH_CHECK_METRIC  --etc
insert into #HEALTH_CHECK_RULE values()
insert into #HEALTH_CHECK_METRIC  values()
We don’t have access to your database so impossible to provide some guidance.
I’ll answer my own question :wink:
I’ve realized that I don’t actually need a series, I just need the value of the most recent metric. I get a better result when I let the database find it for me and let Grafana format the result set as a table.
SELECT CAST(HEALTHY AS INT) AS mwproxy
FROM ima.dbo.HEALTH_CHECK_METRIC a
         INNER JOIN
     (SELECT MAX(METRIC_ID) id
      WHERE APP_NAME = 'mwproxy'
        AND RULE_NAME = 'All checks') b ON a.METRIC_ID = b.id
