Hass.io + InfluxdB + Grafana + Home Assistant Companion
Hi!
I have googled for hours and pursued different solutions but always ended up at a dead end. Help!
I am using Hass.io (0.101.3) on a Raspberry 3b+ with the add-ons Grafana (3.0.0) and InfluxdB (3.3.0). Data flows fine from Hass.io to InfluxdB and is visualized in Grafana.
I then want to get the Grafana panels into Hass.io and are using iframe…
cards:
type: iframe
url: http://192.168.1.65:8123/api/hassio_ingress/8R0NvNvb6b-5pPEF3Z7zvNDIusRAuQtFDEK4pGd-FHQ/d-solo/OMoaJ1mRk/grafana?orgId=1&theme=light&panelId=4
type: iframe
url: http://192.168.1.65:8123/api/hassio_ingress/8R0NvNvb6b-5pPEF3Z7zvNDIusRAuQtFDEK4pGd-FHQ/d-solo/OMoaJ1mRk/grafana?orgId=1&theme=light&panelId=2
…and it works just fine on my desktop computer (windows, chrome) both with local IP and diskstation. me to the raspberry.
But when I try to connect through my phone (iPhone) by either using Chrome or the Home Assistant Companion Beta app the panels are replaced by “401: Unauthorized” if connected to the local LAN and blank panels if on the mobile network. What am I doing wrong?
I have found this lead in the Grafana documentation “this sharing require either anonymous access or setting [cookie_samesite] to none” but aren’t successful in using it.
my Grafana Config
“plugins”: ,
“env_vars”: ,
“log_level”: “info”,
“ssl”: false,
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
Some images of what I see.
Suffering the same issue here too.
Grafana Lovelace panels work fine in Safari (on MacOS), but not in Brave (MacOS), nor Safari on iOS.
Home Assistant 0.102.3 on Hass.io on Ubuntu VM
Grafana 3.0.2 (Hass.io)
InfluxDB 1.0.2 on seperate Debian 9 LXC VM
