Grafana version 5.0.4
Platform: Windows 10
I created a dashboard on my locally running grafana instance, and now want to provide that to another system through provisioning.
I saved my dashboard to a json file.
Created a yaml file in provisioning/dashboards contains the following:
# # config file version
apiVersion: 1
providers:
- name: 'default'
orgId: 1
folder: ''
type: file
options:
path: C:/grafana-5.0.4/dashboards
Placed my dashboard.json file in C:/grafana-5.0.4/dashboards
Run grafana.
My dashboard is created, but it appears it has not mapped the dashboard to the data sources correctly.
Dashboard view displays errors (red triangle in the top left corner of each widget) with:
Datasource named ${DS_STAGE_DEFAULT} was not found.
My datasource does exist, and can be connected to. The datasource on the remote system was created through provisioning (unlike my local system where it was created through the UI).
Beginning of my dashboard.json contains:
"__inputs": [
"name": "DS_STAGE_DEFAULT",
"label": "Stage Default",
"description": "",
"type": "datasource",
"pluginId": "influxdb",
"pluginName": "InfluxDB"
"name": "DS_STAGE_HIGH FREQUENCY",
"label": "Stage High Frequency",
"description": "",
Unsure what I’ve done wrong or what to look at from here.
