- What Grafana version and what operating system are you using?
Grafana 7.3.7 on Docker on Synology NAS
- What are you trying to achieve?
Trying to get a max/min value per day, but pull data from only a specific time range per day (i.e. between 08.00 to 13.00)
- How are you trying to achieve it?
This query works for the full 24h of a day, but I need it to only include a specific time range per day.
SELECT max(“value”) FROM “mqtt_consumer” WHERE (“topic” = ‘tele/BoilerTemp1/temp’) AND $timeFilter GROUP BY time(1d) fill(null)
- What happened?
It includes data from the full 24h of a day rather than a specific time range I need.
This is not a problem I am reporting, hence no errors.
- Did you follow any online instructions? If so, what is the URL?
