I’m using Chrome on a Macbook and the highlight behavior has changed between Grafana 8.3.5 and 9.0.5. -
When I select a log level and/or search term, the matching result should be highlighted in the logs view. -
I have 4 drop-down (3 queries, 1 enum) variables and a search box. This query works fine in both 8.3.5 and 9.0.5 EXCEPT 9.0.5 does not show the highlights. -
What happened?
Highlights are missing -
I expect that the highlighting would work in both versions, or receive some sort of error message.
"__inputs": [
"name": "DS_LOKI-STACK",
"label": "Loki-stack",
"description": "",
"type": "datasource",
"pluginId": "loki",
"pluginName": "Loki"
"__elements": {},
"__requires": [
"type": "grafana",
"id": "grafana",
"name": "Grafana",
"version": "9.0.5"
"type": "panel",
"id": "logs",
"name": "Logs",
"version": ""
"id": "loki",
"name": "Loki",
"version": "1.0.0"
"annotations": {
"list": [
"builtIn": 1,
"datasource": {
"type": "grafana",
"uid": "-- Grafana --"
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"name": "Annotations & Alerts",
"target": {
"limit": 100,
"matchAny": false,
"tags": [],
"type": "dashboard"
"type": "dashboard"
"editable": true,
"fiscalYearStartMonth": 0,
"graphTooltip": 0,
"id": null,
"links": [],
"liveNow": false,
"panels": [
"collapsed": false,
"gridPos": {
"h": 1,
"w": 24,
"x": 0,
"y": 0
"id": 3,
"panels": [],
"title": "Log Viewer",
"type": "row"
"datasource": {
"type": "loki",
"uid": "${DS_LOKI-STACK}"
"gridPos": {
"h": 14,
"w": 24,
"x": 0,
"y": 1
"id": 1,
"options": {
"dedupStrategy": "none",
"enableLogDetails": true,
"prettifyLogMessage": false,
"showCommonLabels": false,
"showLabels": false,
"showTime": false,
"sortOrder": "Descending",
"wrapLogMessage": false
"targets": [
"datasource": {
"type": "loki",
"editorMode": "code",
"expr": "{pod=~\"$pod\",component=~\"$component\",namespace=~\"$namespace\"} |~ `(?i)$logLevel` |~ `(?i)$search`",
"key": "Q-61c5548f-f390-4e80-8a6a-f0974fc33259-0",
"queryType": "range",
"refId": "A"
"title": "$component Logs",
"type": "logs"
"schemaVersion": 36,
"style": "dark",
"tags": [],
"templating": {
"list": [
"current": {},
"datasource": {
"type": "loki",
"definition": "label_values({namespace=~\".+\"},namespace)",
"hide": 0,
"includeAll": true,
"label": "Namespace",
"multi": true,
"name": "namespace",
"options": [],
"query": "label_values({namespace=~\".+\"},namespace)",
"refresh": 1,
"regex": "",
"skipUrlSync": false,
"sort": 1,
"type": "query"
"current": {},
"datasource": {
"type": "loki",
"definition": "label_values({component=~\".+\", namespace=~\"$namespace\"},component)",
"hide": 0,
"includeAll": true,
"label": "Component",
"multi": true,
"name": "component",
"options": [],
"query": "label_values({component=~\".+\", namespace=~\"$namespace\"},component)",
"refresh": 1,
"regex": "",
"sort": 1,
"type": "query"
"current": {},
"datasource": {
"type": "loki",
"definition": "label_values({pod=~\".+\",component=~\"$component\"},pod)",
"hide": 0,
"includeAll": true,
"label": "Pod",
"multi": true,
"name": "pod",
"options": [],
"query": "label_values({pod=~\".+\",component=~\"$component\"},pod)",
"refresh": 1,
"regex": "",
"sort": 1,
"type": "query"
"current": {
"selected": true,
"text": [
"All"
"value": [
"$__all"
"hide": 0,
"includeAll": true,
"label": "Log Level",
"multi": true,
"name": "logLevel",
"options": [
"selected": true,
"text": "All",
"value": "$__all"
"selected": false,
"text": "DEBUG",
"value": "DEBUG"
"selected": false,
"text": "ERROR",
"value": "ERROR"
"selected": false,
"text": "WARN",
"value": "WARN"
"selected": false,
"text": "TRACE",
"value": "TRACE"
"selected": false,
"text": "INFO",
"value": "INFO"
"query": "DEBUG,ERROR,WARN,TRACE,INFO",
"queryValue": "",
"type": "custom"
"current": {
"selected": false,
"text": "",
"value": ""
"hide": 0,
"label": "Search",
"name": "search",
"options": [
"selected": true,
"text": "",
"value": ""
"query": "",
"type": "textbox"
"time": {
"from": "now-15m",
"to": "now"
"timepicker": {},
"timezone": "",
"title": "Explore Test",
"uid": "Xq2Pu784z",
"version": 10,
"weekStart": ""
No errors were returned. -
Did you follow any online instructions? If so, what is the URL?
Just exported my dashboard and re-imported into Grafana 9.0.5 and noticed the highlights were missing.
