I’m using the Stat panel to show some metrics, for example:
status{pod="A"} 1
status{pod="C"} 3
status{pod="B"} 4
And using as Text mode: Value and Field I map {{pod}}
to be the text. So something like this is shown:
A 1
C 3
B 4
But, I’d like to organize the values being displayed on the panel alphabetically by the text being shown (A
, B
, C
So it should always be displayed like:
A 1
B 4
C 3
But I cannot fin such an option.
How can I do that?
wlargou
2
Did you try to use the Transform Tab and select Organize fields.
Good Luck
Hi, Thanks for answering
To use the Organize fields transformation, first I’m forced to apply an Outer join by “Time” and then I can apply Organize fields…
After doing it this way, every time the panel is refreshed the values are randomly displayed again.
system
Closed
4
