Horizontally align vertically stacked panels
I’m new to Grafana and I’m looking for a way to align panels in a dashboard.
I have a number of timeseries panels stacked vertically. Each of the panels has the same time region.
I want the graph part of the panels to be aligned such that the same x values are exactly on the same vertical line. Problem is that the graphs have different (widths) axis labels and legends (the legends are on the right).
This mock-up shows what I’m after.
scrot20220312220710
Is there a way to obtain this?
Thanks for your patience.
welcome to the :grafana: forum, @sciurius
I don’t think this is possible but I may be wrong. Might be worth making a feature request here:
Ok, see Synchronize X-axes of panels · Discussion #46616 · grafana/grafana · GitHub.
