Hi all.
I’m trying to make a bar-gauge that shows per-CPU-core load using node_exporter.
I’ve found that node_cpu_seconds_total{mode!=“idle”} gives me the data for all non-idle processes, but it also outputs all seven categories of load individually, per core, of which I have 32.
Is there a way to get Grafana to sum together the seven categories and output one number for each core? Then I can use “CPU {{cpu}}” as the legend and all is as I want it.
