Grafana V9.3.2
MacOS Ventura
- My data source prevents writing KQL/SQL to directly name the queries. This leads to a default where the query labels to have a ‘multifabric-AB-total’ format.
I am able to override each query individually using field overrides to rename to just ‘AB’, ‘CD’, etc. but it would be ideal if I could reference the ‘query name’, which I can edit for each query, in the display name override under standard options.
When I try {$__series.name} i get {[object Object].name} for all of my query labels. {$__query.name} just returns {$__query.name} as a static name for all query labels.
I’ve tried referencing this document but am not finding any success. Has anyone found a way to do this? It feels like something that should have a standard reference.
