Grafan 9.1.6, Backend DB Grafite -
I have a series of data points of NFS exports per array
I am trying to sum for each array the total of NFS exports -
I have written a local check in CMK that runs once every 24 hours to gather than # of nfs export for each array
An example might assist
query A cmk.array1.nfs exports result 200 - display no
query B cmk.array2.nfs exports result 20 - display no
query C sum( A,B ) result 200 - display yes -
What happened?
query C sum( A,B ) result 220 - display yes -
None received -
Did you follow any online instructions? If so, what is the URL?
No. n/a
Create TopicClose
