Hello all,
I’m currently setting up a few dashboards… the thing which confuses me the most is the time range setting.
For example:
I use a stats panel which receives one value. The current value is 0, 20 minutes ago it was 1 for a few minutes.
Why is the stats panel showing 1 instead of 0 if I select a time range of 6 hours? Shouldn’t display the panel the current live value of 0?
If I set the time range to now-now it shows the right live value but the then there is no graph.
I haven’t found a good explanation of how the time series setting is working…
Regards
SchiSchi
