How to add Authorization: Bearer token with JSON datasource plugin
I am using the JSON datasource plugin and am trying to setup a new URL that uses an authorization: bearer token. How do I enter it? I have tried this (shown below) and also tried with the OAuth toggle selected (instead of With Credentials) and got the same result.
Here is the documentation from the API which I am trying to use: QuickBooks Time API Reference
I tested my URL and bearer token in Node-RED using HTTP GET request and was able to get the data fine, so I know my URL and token work. It’s only in this plugin that I cannot figure out how to insert my token as a Custom HTTP Header
Move Bearer to Value
Header = Authorization
Value = Bearer SomeAuthKey
How do you do token refresh with this plugin?
From my experience, most API access tokens are relatively short lived, and there’s an OAuth2 flow to obtain an access token via a client credentials grant.
