How to add custom label with dynamic value in k6 logs with log-output forwarding?
The default message format for k6 with console.log is
time="2023-07-19T10:40:20Z" level=info msg="hello" source=console
I want to modify this message and let’s say add a custom label like trace=1234 method=login
I want to do this because the logs will be sent to Loki and then I can search by labels like method
How can I achieve this?
I know, I can achieve this by creating a custom javascript extension with a custom log method. I have tried this like following for testing purposes:
    package tracelogger
    import (
        "fmt"
    	"time"
        "go.k6.io/k6/js/modules"
    // init is called by the Go runtime at application startup.
    func init() {
        modules.Register("k6/x/tracelogger", new(TraceLogger))
    type TraceLogger struct{
    func (l *TraceLogger) Log() {
    		currentTime := time.Now()
    		formattedTime := currentTime.Format("2006-01-02T15:04:05Z07:00")
    		fmt.Printf("time=\"%s\" level=info trace=1234 method=abc msg=\"%s\" source=console", formattedTime,  "hello")
Now in the JS test file
    import tracelogger from 'k6/x/tracelogger';
    export const options = {};
    export function setup() { }
    export default function LoadTest() {
      tracelogger.log();
It does print the output but in the standard console as expected
    time="2023-07-19T12:08:18Z" level=info trace=1234 method=abc msg="hello" source=console
Now the problem is I am also forwarding the log output to Loki
    k6 run --log-output=loki=http://localhost:3100/loki/api/v1/push,label.qa=k6 test.js
The log does not get forwarded to Loki, how do I log so that the log gets forwarded to loki?
I also tried with --log-format=raw and direct console.log
    console.log(`trace=1234 msg="aaaa"`);
but the labelling doesn’t work correctly in loki
enter image description here
