I’m on AWS grafana. Not sure what version but most likely the latest. -
Given any time series, for example the one below, kube_pod_container_resource_requests (I need to do this for many metrics but they’re all TS),
- I need to create two sister charts (ie, not inside this chart) that shows the start and end time of this metric’s time series. E.g., this case, first sister chart would show 2023-01-15 10:17:00 (as shown in the png below) and the second would show 2023-01-15 10:24:45 .
- A third chart showing the elapsed time. In this case 07:45.
All three sister charts would be of type “Stat”.
Since I’m learning promQL, please provide me the link to the docs where prospective solution is documented (preferably a link in grafana.com)
I couldn’t find documentation to show the timestamp rather than value. I’ve tried
** increase(kube_pod_container_resource_requests{container=“spark-kubernetes-driver”,pod=“$driver_id”,resource=“cpu”,prometheus_replica=“prometheus-k8s-1”}[1m])
** avg_over_time(kube_pod_container_resource_requests{container=“spark-kubernetes-driver”,pod=“$driver_id”,resource=“cpu”,prometheus_replica=“prometheus-k8s-1”}[1m])
** time((kube_pod_container_resource_requests{container=“spark-kubernetes-driver”,pod=“$driver_id”,resource=“cpu”,prometheus_replica=“prometheus-k8s-1”})) -
What happened?
All attempts to display the timestamp failed -
I expected to see the initial timestamp, the final timestamp and the elapsed duration of the given metric -
No -
Did you follow any online instructions? If so, what is the URL?
I couldn’t find any links pointing to calculating the time difference between two specific time series data points.
