I have copied a module, changed the plugin.json, commented out some lines of code in module.ts.
Now I guess I need to ‘compile’ this to a module.js?
What is the simplest way of doing this on CentOS6/&. (without installing tons of rpms etc)
Yes saw that already, I was looking for a one liner that quickly transforms the ts, like
g++ -o hi hi.cpp
Don’t have one ready as it is easier to just run grunt. But you could use the TypeScript tsc tool to build one file.
