i use the text panel to show some useful information for viewers.
the problem is that ,when i fill the text panel with many lines of words,
i use grafana-reporte to generate pdf,
no nore than three lines can ben show,
the other lines was lost ,
how can i fix the problem
it is very urgent,than you
This does not look like a grafana product?
Might want to ask in above repo
thank you ,it is my problem,in fact ,this problem occur only because i forgot to use an useful parameter.
This important parameter called -grid-layout,only use this parameter,the grafana-reporter can count the pannel by its really height.this problem only affect text pannel,so i made this mistake
