I know it is possible due to seeing it here: https://grafana.com/static/assets/img/blog/transformer-fault-gas-and-duval-analysis.jpg
But not sure which plugin they used to do it. If anyone knows I would appreciate some help.
They probably used the plotty plugin
See this thread
https://localhost:3000/t/how-to-use-plotly-panel-in-grafana/87948/2
And this post
What is your data source
Using 2 type of plotty plugins
