How to create a pie chart with %
Hi there,
I’m a beginner here, you will find below the details.
Thank you for your help.
    v8.0.3 on Chrome
    A pie chart representation
    From a Postgresl table.
The table view look like this :
Date | Modality | sum_modality
2021-09-02 | AC | 4
2021-09-02 | AB | 3
2021-09-02 | CA | 3
2021-09-01 | CA | 2
2021-09-01 | BG | 6
2021-08-31 | BG | 3
2021-08-31 | AC | 3
  • What happened?
    Didn’t achieve to well set up the pie chart to display the distribution with a filter per date.
    I would like to display the distribution in pourcent. For exemple if I choose to filter only on this date ‘2021_09-02’, the pie chart is suppose to show 25% AC, 33,3%, AB 33,3% CA.
And if I choose to filter on several date, rates should be automaticly update.
select
  $__timeGroup(date, 1d),
  modality,
  sum(count_modality) as sum_modality
from
  schema.table
GROUP BY
  date,
  modality,
  count_modality
    no
    Didn’t find relevant instructions
Welcome to the Grafana forums.
Can you show us what your data looks like in Table view (switch the toggle at the top of the screen). For example, my pie chart in Table view looks like this:
and the pie chart looks like this, where you can see the amounts in percent. The chart changes as I change the date range (e.g. last 90 days, last year, etc.):
I succeed in resolving my problem finally thank you :slight_smile:
SELECT
  $__timeGroupAlias(date,$__interval),
  sum(count_modality) AS "count_modality",
  modality AS "modality"
FROM <table>
WHERE
  $__timeFilter(date)
GROUP BY 1, modality
ORDER BY 1
