Hi Folks,
Can any one please help me how to create custom Plugins, as i’m very new to grafana. Suggetions and guidance are appreciated. Thanks in advance.
Did you find the docs pages for developing plugins?
http://docs.grafana.org/plugins/developing/development/
Otherwise a good tip is to find a plugin that is similar to the one you want to build and starting by copying that one. For data sources, some good starter plugins are:
- https://github.com/grafana/simple-json-datasource
- If you want to write it in TypeScript: https://github.com/grafana/typescript-template-datasource
