Hello everybody,
I am currently trying to write my own datasource plugin by following this guide from the docs, but I am getting the following error messages in my logs:
logger=data-proxy-log userId=0 orgId=1 uname=
path=/api/datasources/proxy/uid/b89157b7-f08b-4ff4-8128-0e14c7b5afb7/
testsource/v1 remote_addr=172.24.0.1 referer=http://grafana.staged-by-discourse.com/datasources/edit/b89157b7-f08b-4ff4-8128
-0e14c7b5afb7 t=2023-07-03T12:30:05.085512256Z level=error
msg="Proxy request failed" err="tls: failed to verify certificate: x509:
cannot validate certificate for 10.77.14.47 because it doesn't contain any IP SANs"
As you can see I am using a self-signed certificate and access the API via IP - this is a common scenario for us so I’d really need to know if I can deactivate SSL verification in my call to getBackendSrv().dataSourceRequest()
, which currently looks like this (implemented in the healtcheck):
async testDatasource() {
const routePath = "/testsource";
const fullUrl = this.url + routePath + "/v1";
console.log(fullUrl);
const result = await getBackendSrv().datasourceRequest({
method: "GET",
url: fullUrl,
responseType: "json",
headers: {
"Accept": "application/json",
if (result.status !== 200) {
return {
status: 'error',
message: 'Error',
} else {
return {
status: 'success',
message: 'Success',
Edit: I did some digging in the official source code and found lots of information e.g. on the Prometheus datasource’s ConfigEditor.ts
- could I reuse code from there, since it’s a similar scenario (Grafana connecting to an instance with an unknown certificate on my behalf)?
Any help is highly appreciated,
Best regards,
Daniel
