How to display domain name instead of ip address in cadvisor and node exporter dashboard
In the node dropdown it shows IP address as this is not static config , so internal IP address shows up what container ip nic has got.
showing_ip_addresses
    8.1.5
Display domain name instead of ip address
@niceguysan are you trying to use a ore-built dashboard from grafana.com?
can you screenshot the settings for that template variable?
no the grafana instance is running via container, sorry for late reply .
I have not defined a template variable yet, or maybe I am miss understanding.
