How to display elasticsearch data Difference graph
I have some number data collected every day from elasticseach
I have a question
・ How to get and draw difference data for each day
ex)
November1
HOST A:100
HOST B:300
November2
HOST A:120
HOST B:280
Graph show November2
⇒HOST A:20
HOST A:-20
elasticsearch:6.6.1
grafana:6.4.3
You should use another datasource such as Metaqueries.
Thanks.
Investigate and use Metaqueries if necessary
After examining Metaqueries, the following URL was found.
It seems that the previous day’s data can be displayed in TimeShift, but it does not seem to be able to arithmetic calculations based on that data.
Is there any solution?
「TimeShift on arithmetic is not supported」
Try CompareQueries Datasource
Fadjar Tandabawana
