How to display multiple lines in the Stat Panel
My panel has only one row.like this:
I want to divide these 10 squares grid into two rows.Achieve an effect like this:
What should i do?
I’m using Grafana 6.7 and also not able to wrap the lines.
I only have horizontal or vertical 1 colum.
Is there a way to set the maximum number of items on a line?
@desistdaydream @machielvanampting Did you ever figure this out? I’m having the same problem
