How to Display the Int values with String in Stats Panel
I have two Prometheus metrics
metrics 1: mysql_global_status_threads_connected
value 1 : 10
metrics 2: mysql_global_variables_max_connections
value 2: 50
I need to show the output as “10/50”
How can I achieve this in the stats panel?
Any idea for the above request?
You gonna have to get a bit innovative
Instead of Stats use Canvas or svg plugin. Then using javascript you can concatenate those values.
https://localhost:3000/t/svg-panel-sql-server-query/65877/5
