- What Grafana version and what operating system are you using?
grafana-9.1.5-1.x86_64 & RHEL 7.9 -
Trying to install Grafana on a data disk instead of OS disk. But not able to start Grafana Seems i need to add some links to service file.
Need some guidanc eon this.
yum localinstall .rpm --rootinstall=path -
What happened?
it installs all libs/var etc to the given path. But when i try systemd start the system cant find the service file. -
Did you follow any online instructions? If so, what is the URL?
