How to enable Metrics-generator for Tempo in Grafana Cloud
    Grafana Cloud
    I have a client app with OpenTelemtry which is able to write to Tempo with an OpenTelemetry collector.
    Now I want to get the APM data by using the metrics-generator. But I was not able to find how to enable in the cloud.
  • What happened?
    nothing
    getting a prometheus dashboard with the APM data of my client app.
    here are some intormation
    Configuration | Grafana Tempo documentation
but again, where to apply?
metrics-generator is not enabled by default in Grafana Cloud.
you need to open a support ticket to enable it, can you open a ticket please, see Grafana Cloud support options | Grafana Cloud documentation for more details.
