How to filter in query?
    —> Grafana Cloud (free tier) with AWS Timestream as datasource.
    —> Filter data from the time series database before it gets graphed.
    ----> I want to make the data that gets selected conditional on the value of a field.
  • What happened?
    —> I can’t make the query work
I currently have this query working:
SELECT * FROM “DBNAME”.“TABLENAME” WHERE measure_name = ‘temp’
It doesn’t filter on device ID. (I want to graph per device, but all logs are in the same timesteam db).
The fields in the timestream database are:
time - timestamp
location - VARCHAR with description of location
measure_name - “temp”
measure_value::double - value of the measured temperature value (e.g. 24.1 or 19.6)
measure_name - “deviceID”
measure_value::double - the ID of the device uploading (eg. 33.0 or 44.2 etc).
I would like to have a query that only selects where the value of the row with deviceID is a certain number. Something like this:
SELECT * FROM “DBNAME”.“TABLENAME” WHERE measure_name = ‘temp’ AND WHERE measure_value::double(of deviceID) = 33.0.
But I can’t get this to work. Either I’m doing something wrong with storing the time series in the database, or I’m doing something wrong filtering it.
Any help?
Have you tried writing a query and then querying the database directly? It sounds like it might be worth trying to achieve that first, then you can troubleshoot the Grafana layer…
Hello @djvanhelmond!
Were you able to resolve this issue?
I am also stuck at something similar. I want to filter data before it gets graphed but I am not sure how to do it.
I would really appreciate if you could help.
Hi @bieintern,
You need to store the device id (or the value that you want to sort on) as a dimension in the record. It becomes a new column in the TS database.
https://boto3.amazonaws.com/v1/documentation/api/latest/reference/services/timestream-write.html#TimestreamWrite.Client.write_records
