I have been working together with Prometheus and Grafana where I am trying to integrate them both together. My problem currently is that my node exporter is currently redirecting to port 9100 which I was able to do:
By doing
node_memory_MemTotal_bytes{job=“node”,instance=~“localhost:9100”}
However this would just sum up the whole computer status but what I want to do is that I would like to get RAM usage of each target:
# Sample config for Prometheus.
global:
scrape_interval: 1s # Set the scrape interval to every 15 seconds. Default is every 1 minute.
evaluation_interval: 1s # Evaluate rules every 15 seconds. The default is every 1 minute.
# scrape_timeout is set to the global default (10s).
# Attach these labels to any time series or alerts when communicating with
# external systems (federation, remote storage, Alertmanager).
external_labels:
monitor: 'example'
# Alertmanager configuration
alerting:
alertmanagers:
- static_configs:
- targets: ['localhost:9093']
# Load rules once and periodically evaluate them according to the global 'evaluation_interval'.
rule_files:
# - "first_rules.yml"
# - "second_rules.yml"
# A scrape configuration containing exactly one endpoint to scrape:
# Here it's Prometheus itself.
scrape_configs:
- job_name: node
# If prometheus-node-exporter is installed, grab stats about the local
# machine by default.
static_configs:
- targets: [
'localhost:8000',
'localhost:8001',
'localhost:8002',
'localhost:8003',
'localhost:8004',
'localhost:8005',
'localhost:8006',
'localhost:8007',
'localhost:8008',
'localhost:8009',
'localhost:8010',
'localhost:8011',
'localhost:8012',
'localhost:8013',
'localhost:8014',
'localhost:8015',
'localhost:8016',
'localhost:8002',
'localhost:8017',
'localhost:8018',
'localhost:8019',
'localhost:8020',
'localhost:8021',
'localhost:8022',
'localhost:8023',
'localhost:8024',
'localhost:8025',
'localhost:8026',
'localhost:8027',
'localhost:8028',
'localhost:8029',
'localhost:8030',
'localhost:8030',
'localhost:8031',
'localhost:8032',
'localhost:8033',
'localhost:8034',
'localhost:8035',
'localhost:8036',
'localhost:8037',
'localhost:8038',
'localhost:8039',
'localhost:8040',
'localhost:9100'
and now I am stuck where I do not know how or if its even possible to get the RAM usage that is being used by the different ports?
The output I would like to do is:
