Hi
I’d like the user of my load testing script to be able to input a string before the script is ran.
Is this possible somehow? I tried readline() but that produced an “not defined” error.
Hi
Sure, you can pass environment variables to k6 script via the --env key=value
flag, and then access their values via __ENV[key]
in your script. You can read more about it here: Environment variables
And if you want to actually input things in the terminal, you can wrap the k6 run
call in a shell script like this:
echo "Type whatever data you need:"
read mydata
k6 run --env mydata="$mydata" script.js
