As depicted above I need to change the time range from 6 hours to 5mins, but once I have changed it, other panels time range changes in that dashboard as well. Is there anything I can do to change the time range only for one widget? , there were some similar questions and answers but most of them are outdated and related to influxDB , It would be great if someone can help me with this issue, Thank
Hi @chamathjayasekara99,
You can set different time ranges for any data source by using “Query options” → “Relative time”. Please check answer on next link:
https://localhost:3000/t/each-panel-has-its-own-timeline/79929/4?u=ldrascic
Hope this helps.
Best regards,
ldrascic
Thank you so much ! for your response, Also one question, Is it possible to remove the time picker from each panel ?, can it be done changing the json format of the query ?
Can you show me what do you mean by term “time picker”?
If you are referring to blue letters that appear in upper right corner of a panel e.g. “Last 1h” when using Relative time option, you can toggle that off by clicking on “Hide time info” inside Query Options.
Best regards,
ldrascic
Why you want to remove it? What issue are you trying to solve?
You can hide time picker in Dashboard settings (cog icon) -> General
Best regards,
ldrascic
