The lines fluctuate a lot and quick over the day, resulting in a hard to read chart.
My data has a resolution of 10 seconds.
In this example there are about 80 pixel per hour, so I would need to group and avg the data by ~45seconds to get a sample point per pixel.
Can this be done somehow?
Here is my current query:
SELECT
$__time(timestamp),
carport_P AS `PV Carport`,
roof_P AS `PV Dach`,
gen_P AS `MI`,
`battery_P` AS `Akku`,
`grid_P` AS `Netz`,
`load_total_P` AS `Verbrauch`,
`battery_SOC` AS `Akku SOC`
FROM
log.pv
WHERE
$__timeFilter(timestamp)
ORDER BY
timestamp DESC
Ok, found it out eventually.
The keyword here is $__interval_ms.
It is replaced by a number.
For example when I scale to last 2 days, I get 120000.
This is more or less the interval of a pixel. Not exactly though. This hints that there is a way to add custom variables. I cannot make it work yet though.
SELECT
`time`,
CASE
WHEN `Akku` < 0 THEN `Akku`
ELSE 0
END AS `Akku laden`,
CASE
WHEN `Akku` > 0 THEN `Akku`
ELSE 0
END AS `Akku entladen`,
CASE
WHEN `Netz` > 0 THEN `Netz`
ELSE 0
END AS `Einspeisung`,
`MI`,
`PV Carport`,
`PV Dach`,
CASE
WHEN `Netz` < 0 THEN `Netz`
ELSE 0
END AS `Netzbezug`,
`Verbrauch`,
`Akku SOC`
FROM
SELECT
ROUND(
ROUND(
UNIX_TIMESTAMP(`timestamp`) * 1000 / $__interval_ms
) * $__interval_ms
) AS `time`,
AVG(gen_P) AS `MI`,
AVG(carport_P) AS `PV Carport`,
AVG(roof_P) AS `PV Dach`,
AVG(`battery_P`) AS `Akku`,
- AVG(`grid_P`) AS `Netz`,
AVG(`load_total_P`) AS `Verbrauch`,
AVG(`battery_SOC`) AS `Akku SOC`
FROM
log.pv
WHERE
GROUP BY
`time`
ORDER BY
`time` DESC
) AS `t`
Here is the result of grouping the values by interval.
to group and average your data by 45 seconds, you can use the following query:
SELECT
mean(carport_P) AS PV Carport,
mean(roof_P) AS PV Dach,
mean(gen_P) AS MI,
mean(battery_P) AS Akku,
mean(grid_P) AS Netz,
mean(load_total_P) AS Verbrauch,
mean(battery_SOC) AS Akku SOC
FROM
log.pv
WHERE
GROUP BY
time(45s)
ORDER BY
timestamp DESC
This query will group the data by 45-second intervals, and calculate the average value for each group. The resulting data points will be spaced approximately 45 seconds apart, which should result in a more readable chart.
