9.4.3 -
Change default dashboard location to a different folder aside from General or make General Folder read-only. -
Through using the UI. I don’t see any options for doing this. -
What happened?
A new dashboard accidentally got added to the General folder by default and was accessible to all users on the server for a period of time. -
We heavily use teams to restrict access to dashboards. When an admin user creates a new dashboard we sometimes mistakenly leave this in the General folder but would prefer to keep it in a different folder with restricted team access. Organizations are not the solution for us as they are a bit too restrictive. -
not really applicable. -
no -
Did you follow any online instructions? If so, what is the URL?
