How to select a variable index
Hi all,
Really sorry but was hoping someone could explain to me how I am able to select from a list of multiple variables in a query so that I only return a single variable in position 1,2,3 or 4 from the example below:
variable_name contains the following values
AAA
BBB
CCC
DDD
I tried indexing it using the following format but this doesnt seem to work.
WHERE MY_VALUE = {variable_name:1} OR
WHERE MY_VALUE = {variable_name:3}
I have looked at the documentation and here on the community forums but I am either going blind or it is just something that isnt supported?
Any help would be greatly appreciated. Loving Grafana so far!
Wondering if there were any updates that allowed this behavior. I’m using a plugin where I make multiple requests to a JSON API and would like to save some object ids in a variable. When writing the path to requests in queries, I would like to use this variable like this:
A:
/path/to/api/object/${object:0}
B:
/path/to/api/object/${object:1}
Instead of : you can use . ${object.0}
