- What Grafana version and what operating system are you using?
“version”: “9.3.0-beta.1” -
Use Canvas plugin and I need to add background color for string metric. The color is changed according to the string.
Example:
Production => Green color
QA => Yellow color
Development => Orange color
etc… -
I added item as metric value that is string. For now I use another numeric metric to set background that is not related at all. - What happened?
I work, but not the good way to do that. Since I use one existed numeric value as “Response time ms”. This is not realted at all to the Environment string : Production, QA, Dev… - What did you expect to happen?
How I can set the threshold on string metric that work as expected independently. - Can you copy/paste the configuration(s) that you are having problems with?
N/A - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No errors - Did you follow any online instructions? If so, what is the URL?
I didn’t find accurate data in the confluence except for :
Canvas | Grafana documentation
Any update on this please?
