How to solve file upload problem?
I have a problem with k6 file upload. By the way formData.body() returns [object ArrayBuffer] in the console
Taking 500 error which inclues below;
"code":500,"applicationErrorCode":-1,"message":"Unknown Error","exceptionContent":"System.NullReferenceException: Object reference not set to an instance of an object.\n
My code below;
import { describe } from "https://jslib.k6.io/expect/0.0.4/index.js";
import { FormData } from 'https://jslib.k6.io/formdata/0.0.2/index.js';
import exec from "k6/execution";
import { check } from 'k6';
import http from "k6/http";
import Load, { Roles } from "../../../core/load.js";
let endpoints = JSON.parse(open("../../../core/endpoint.json"));
let file = open('../../../utils/waybill.jpg','b')
export function setup() {
    let supportAuth = Load.auth(Roles.Support);
    let waysSeedRes = http.post(
        Load.api + endpoints.Debug.Seed + '?seeds=Ways',
            headers: {
                Authorization: `Bearer ${supportAuth.json().access_token}`,
                "Content-Type": "application/json",
                apikey: "test"
    return [
        supportAuth.json(),
        waysSeedRes .json()
const totalVu = 1;
export const options = {
    summaryTimeUnit: "ms",
    scenarios: {
        Ways: {
            exec: "Ways",
            executor: "per-vu-iterations",
            vus: totalVu,
            iterations: 1,
export function Ways(data) {
    let tokenForSupport = data[0].access_token;
    describe("Ways scenerio", (t) => {
        const formData = new FormData()
        formData.append('file', file)
        const res = http.post(Load.api + endpoints.Waybills.uploadWaybillImage, formData.body(), {
            headers: {
                Authorization: `Bearer ${tokenForSupport}`,
                 apikey: "test",
                'Content-Type': 'multipart/form-data'
        console.log("fileUpload",res.body)
        check(res, {
            'is status 200': (r) => r.status === 200,
Hi @Yusuf !
Have you tried to use http.file? See documentation Data Uploads.
“code”:500,“applicationErrorCode”:-1,“message”:“Unknown Error”,“exceptionContent”:"System.NullReferenceException: Object reference not set to an instance of an object.\n
Is it from the response logs? :thinking: I guess the actual error is presented in the server logs.
Let me know know if that answers,
Cheers!
@olegbespalov tried http.file but got same error. I guess , this is related to our server error. You are right
