Hi all,
I created a dashboard with some diffrent SingleStat. (With MySQL datasource.) Each single in this dashboard is a “Select COUNT() FROM …,” so i get differents numbers. I want to get a sum of this differents “SELECT COUNT()”, in a new dashboard ?
How can i do ?
Thanks in advance.
You cannot do this, you have to write the complete query
My different result count come from different database, so i had to create multiple datasource to connect on my different database client.
Maybe i can use multiple datasource in one SingleStat module ?
Its current not possible to combine data from different databases, you can query different datasources in same graph if you use the mixed datasource
