- What Grafana version and what operating system are you using?
9.0.6 - What are you trying to achieve?
i have a metrics which the latency from my host to a host.
such as
# HELP connect_to_google the latency of http get google.com. uint ms. 0 means timeout
# TYPE connect_to_google gauge
connect_to_google{host = "kuku" } 171.94
base on this metrics i want visualize
- the latency change over time which could be done via time series chart.
- the health state of this host, it may be done via state timeline chart. im not sure about it.
i ceate two query and set different visualization to them but it does not work.
What else
it seems a common question around the community
https://localhost:3000/t/how-can-i-put-two-visualizations-in-one-panel/58531
https://localhost:3000/t/display-two-visualizations-in-the-same-panel/32800
but i still don’t how to achieve or could it be achieved.
i alose noticed that stat chart have a option to enable the sparkline mode. which seem exactly what i want to archieve. it combine stat chart and a time series chart in same panel.
but im not sure could it be done in other combination.
