Hello, guys!
I need to calculate the load metric for each of the API methods per request. Is it correct to do this using the timings.duration metric in the following script ?
import {group, check} from "k6";
import {
allSportsDuration,
eventTypesDuration,
eventDetailsDuration,
eventExternalInfoDuration,
eventsDuration,
favouritesChampsDuration,
highlightsDuration,
liveEventsDuration,
liveNowDuration,
menuBySportDuration,
topSportMenuDuration,
topSportsDuration,
upcomingDuration,
staticTranslationsDuration,
marketTypeGroupsDuration,
selectionCodesDuration,
breadCrumbNavItemDuration,
marketNamesDuration,
centralEventsDuration,
eventsByNameDuration,
eventByCodeDuration,
popularBetsDuration,
errorRate,
options
} from "../config.js";
import {getAllSports} from "../api/allSports.js";
import {getEvents} from "../api/events.js";
import {getFavouritesChamps} from "../api/favouritesChamps.js";
import {getHighlights} from "../api/highlights.js";
import {getMenuBySport} from "../api/menuBySport.js";
import {getTopSportMenu} from "../api/topSportMenu.js";
import {getTopSports} from "../api/topSports.js";
import {getUpcoming} from "../api/upcoming.js";
import {getEventDetails} from "../api/eventDetails.js";
import {getEventExternalInfo} from "../api/eventExternalInfo.js";
import {getLiveEvents} from "../api/liveEvents.js";
import {getLiveNow} from "../api/liveNow.js";
import {getEventTypes} from "../api/eventTypes.js";
import {getEventByCode} from "../api/eventByCode.js";
import {getBreadCrumbNavItem} from "../api/getBreadCrumbNavItem.js";
import {getMarketNames} from "../api/getMarketNames.js";
import {getSelectionCodes} from "../api/getSelectionCodes.js";
import {getMarketTypeGroups} from "../api/getMarketTypeGroups.js";
import {getStaticTranslations} from "../api/getStaticTranslations.js";
import {getPopularBets} from "../api/popularBets.js";
import {getCentralEvents} from "../api/getCentralEvents.js";
import {getEventsByName} from "../api/eventsByName.js";
import {
getEventIdsFromEvents,
getTopSportIds,
getSportIdsFromAllSports,
getSportIdsWithLiveEventsFromAllSports,
getEventCodes
} from "../helpers/helpers.js";
export {options};
let eventIds = [];
let eventCodes = [];
let sportids = [];
let liveSportIds = [];
let topSportsIds = [];
let langIds = [2, 3, 4, 5, 6, 7, 8, 9, 12, 13, 15, 17, 36, 37, 38, 39, 40, 41, 51, 58, 59, 60, 63, 64, 65, 66, 67, 68, 69, 74, 75, 79, 81, 82];
export default function () {
group("allSports", function () {
const allSportsResult = getAllSports(langIds);
sportids = getSportIdsFromAllSports(allSportsResult);
liveSportIds = getSportIdsWithLiveEventsFromAllSports(allSportsResult);
let success = check(allSportsResult, {
"status is 200 OK": (allSportsResult) => allSportsResult.status === 200,
"content-type is application/json": (allSportsResult) => allSportsResult.headers['Content-Type'] === "application/json; charset=utf-8",
errorRate.add(!success);
allSportsDuration.add(allSportsResult.timings.duration);
group("menuBySport", function () {
const menuBySportRes = getMenuBySport(langIds, sportids);
let success = check(menuBySportRes, {
"status is 200 OK": (menuBySportRes) => menuBySportRes.status === 200,
"content-type is application/json": (menuBySportRes) => menuBySportRes.headers['Content-Type'] === "application/json; charset=utf-8",
menuBySportDuration.add(menuBySportRes.timings.duration);
group("getEvents", function () {
const getEventsRes = getEvents(langIds, sportids);
eventIds = getEventIdsFromEvents(getEventsRes);
eventCodes = getEventCodes(getEventsRes);
let success = check(getEventsRes, {
"status is 200 OK": (getEventsRes) => getEventsRes.status === 200,
"content-type is application/json": (getEventsRes) => getEventsRes.headers['Content-Type'] === "application/json; charset=utf-8",
// "events count is equal 10": (res) => JSON.parse(res.body).Result.EventsCount === 10,
eventsDuration.add(getEventsRes.timings.duration);
group("topSports", function () {
const topSportsRes = getTopSports(langIds);
topSportsIds = getTopSportIds(topSportsRes);
let success = check(topSportsRes, {
"status is 200 OK": (topSportsRes) => topSportsRes.status === 200,
"content-type is application/json": (topSportsRes) => topSportsRes.headers['Content-Type'] === "application/json; charset=utf-8",
topSportsDuration.add(topSportsRes.timings.duration);
group("upcoming", function () {
const upcomingRes = getUpcoming(langIds, topSportsIds);
let success = check(upcomingRes, {
"status is 200 OK": (upcomingRes) => upcomingRes.status === 200,
"content-type is application/json": (upcomingRes) => upcomingRes.headers['Content-Type'] === "application/json; charset=utf-8",
upcomingDuration.add(upcomingRes.timings.duration);
group("topSportMenu", function () {
const topSportMenuRes = getTopSportMenu(langIds);
let success = check(topSportMenuRes, {
"status is 200 OK": (topSportMenuRes) => topSportMenuRes.status === 200,
"content-type is application/json": (topSportMenuRes) => topSportMenuRes.headers['Content-Type'] === "application/json; charset=utf-8",
topSportMenuDuration.add(topSportMenuRes.timings.duration);
group("highlights", function () {
const highlightsRes = getHighlights(langIds, topSportsIds);
let success = check(highlightsRes, {
"status is 200 OK": (highlightsRes) => highlightsRes.status === 200,
"content-type is application/json": (highlightsRes) => highlightsRes.headers['Content-Type'] === "application/json; charset=utf-8",
highlightsDuration.add(highlightsRes.timings.duration);
group("eventDetails", function () {
const eventDetailsRes = getEventDetails(langIds, eventIds);
let success = check(eventDetailsRes, {
"status is 200 OK": (eventDetailsRes) => eventDetailsRes.status === 200,
"content-type is application/json": (eventDetailsRes) => eventDetailsRes.headers['Content-Type'] === "application/json; charset=utf-8",
eventDetailsDuration.add(eventDetailsRes.timings.duration);
group("favouritesChamps", function () {
const favouritesChampsRes = getFavouritesChamps(langIds);
let success = check(favouritesChampsRes, {
"status is 200 OK": (favouritesChampsRes) => favouritesChampsRes.status === 200,
"content-type is application/json": (favouritesChampsRes) => favouritesChampsRes.headers['Content-Type'] === "application/json; charset=utf-8",
favouritesChampsDuration.add(favouritesChampsRes.timings.duration);
group("eventExternalInfo", function () {
const eventExternalInfoRes = getEventExternalInfo(langIds, eventIds);
let success = check(eventExternalInfoRes, {
"status is 200 OK": (eventExternalInfoRes) => eventExternalInfoRes.status === 200,
"content-type is application/json": (eventExternalInfoRes) => eventExternalInfoRes.headers['Content-Type'] === "application/json; charset=utf-8",
eventExternalInfoDuration.add(eventExternalInfoRes.timings.duration);
group("GetEventTypes", function () {
const eventTypesRes = getEventTypes(langIds, sportids);
let success = check(eventTypesRes, {
"status is 200 OK": (eventTypesRes) => eventTypesRes.status === 200,
"content-type is application/json": (eventTypesRes) => eventTypesRes.headers['Content-Type'] === "application/json; charset=utf-8",
eventTypesDuration.add(eventTypesRes.timings.duration);
group("GetEventByCode", function () {
const eventByCodeRes = getEventByCode(langIds, eventCodes);
let success = check(eventByCodeRes, {
"status is 200 OK": (eventByCodeRes) => eventByCodeRes.status === 200,
"content-type is application/json": (eventByCodeRes) => eventByCodeRes.headers['Content-Type'] === "application/json; charset=utf-8",
eventByCodeDuration.add(eventByCodeRes.timings.duration);
group("GetBreadCrumbNavItem", function () {
const breadCrumbNavItemRes = getBreadCrumbNavItem(langIds, sportids);
let success = check(breadCrumbNavItemRes, {
"status is 200 OK": (breadCrumbNavItemRes) => breadCrumbNavItemRes.status === 200,
"content-type is application/json": (breadCrumbNavItemRes) => breadCrumbNavItemRes.headers['Content-Type'] === "application/json; charset=utf-8",
breadCrumbNavItemDuration.add(breadCrumbNavItemRes.timings.duration);
group("GetMarketNames", function () {
const marketNamesRes = getMarketNames(langIds, sportids);
let success = check(marketNamesRes, {
"status is 200 OK": (marketNamesRes) => marketNamesRes.status === 200,
"content-type is application/json": (marketNamesRes) => marketNamesRes.headers['Content-Type'] === "application/json; charset=utf-8",
marketNamesDuration.add(marketNamesRes.timings.duration);
group("GetSelectionCodes", function () {
const selectionCodesRes = getSelectionCodes(langIds);
let success = check(selectionCodesRes, {
"status is 200 OK": (selectionCodesRes) => selectionCodesRes.status === 200,
"content-type is application/json": (selectionCodesRes) => selectionCodesRes.headers['Content-Type'] === "application/json; charset=utf-8",
selectionCodesDuration.add(selectionCodesRes.timings.duration);
group("GetMarketTypeGroups", function () {
const marketTypeGroupsRes = getMarketTypeGroups(langIds, sportids);
let success = check(marketTypeGroupsRes, {
"status is 200 OK": (marketTypeGroupsRes) => marketTypeGroupsRes.status === 200,
"content-type is application/json": (marketTypeGroupsRes) => marketTypeGroupsRes.headers['Content-Type'] === "application/json; charset=utf-8",
marketTypeGroupsDuration.add(marketTypeGroupsRes.timings.duration);
group("GetStaticTranslations", function () {
const staticTranslationsRes = getStaticTranslations(langIds);
let success = check(staticTranslationsRes, {
"status is 200 OK": (staticTranslationsRes) => staticTranslationsRes.status === 200,
"content-type is application/json": (staticTranslationsRes) => staticTranslationsRes.headers['Content-Type'] === "application/json; charset=utf-8",
staticTranslationsDuration.add(staticTranslationsRes.timings.duration);
group("GetPopularBets", function () {
const popularBetsRes = getPopularBets(langIds);
let success = check(popularBetsRes, {
"status is 200 OK": (popularBetsRes) => popularBetsRes.status === 200,
"content-type is application/json": (popularBetsRes) => popularBetsRes.headers['Content-Type'] === "application/json; charset=utf-8",
popularBetsDuration.add(popularBetsRes.timings.duration);
group("GetCentralEvents", function () {
const centralEventsRes = getCentralEvents(langIds);
let success = check(centralEventsRes, {
"status is 200 OK": (centralEventsRes) => centralEventsRes.status === 200,
"content-type is application/json": (centralEventsRes) => centralEventsRes.headers['Content-Type'] === "application/json; charset=utf-8",
centralEventsDuration.add(centralEventsRes.timings.duration);
group("GetEventsByName", function () {
const eventsByNameResp = getEventsByName(langIds);
let success = check(eventsByNameResp, {
"status is 200 OK": (eventsByNameResp) => eventsByNameResp.status === 200,
"content-type is application/json": (eventsByNameResp) => eventsByNameResp.headers['Content-Type'] === "application/json; charset=utf-8",
eventsByNameDuration.add(eventsByNameResp.timings.duration);
group("liveEvents", function () {
let liveEventsResp = getLiveEvents(langIds, liveSportIds);
let success = check(liveEventsResp, {
"status is 200 OK": (liveEventsResp) => liveEventsResp.status === 200,
"content-type is application/json": (liveEventsResp) => liveEventsResp.headers['Content-Type'] === "application/json; charset=utf-8",
liveEventsDuration.add(liveEventsResp.timings.duration);
group("liveNow", function () {
let liveNowResp = getLiveNow(langIds, topSportsIds);
let success = check(liveNowResp, {
"status is 200 OK": (liveNowResp) => liveNowResp.status === 200,
"content-type is application/json": (liveNowResp) => liveNowResp.headers['Content-Type'] === "application/json; charset=utf-8",
liveNowDuration.add(liveNowResp.timings.duration);
For example for one of the tested methods Iâm calculation metric by the following command:
Metric variable was added in separate js script as:
export let allSportsDuration = new Trend(âall_sports_durationâ);
