I want to group fields with count less than 50 into a separate field called "Others"
Hi all , I am using grafana version 7.10 and want to group fields with count less than 50 into a separate field called “Others” . Please help.
  • What happened?
What is your data source?
Dataasource : elasticsearch
Could you please post sample of what your data looks like?
column 1 column 2
A 200
B 190
C 131
D 81
E 41
F 11
I want it like this →
column 1 column 2
A 200
B 190
C 131
D 81
Others 52
ran into an issue with my grafana being http and my elastic search https. will post back if sorted out.
here you go something like this? @skandupadhyay
Under standard Options change Decimal to 0. On Alias field of first query add Others
