iFrame display issue inside panel
Hello all,
I have an issue. We are trying to add an iframe into a panel using the HTML option. When we add the iframe, the outline of it appears, however inside the iframe appears to be blank. I have enabled allow embedding, so not sure what the next step is to resolve this.
Thanks!
@packetprincess Have you received any support or found a solution?
It seems like there is little activity on multiple posts about this same issue.
