I am trying to import winston logger for customizing logging into the file but getting the following error
The moduleSpecifier "winston" has no scheme but we will try to resolve it as remote module. This will be deprecated in the future and all remote modules will need to explicitly use "https" as scheme. GoError: Module specifier "winston" was tried to be loaded as remote module by prepending "https://" to it, which didn't work. If you are trying to import a nodejs module, this is not supported as k6 is _not_ nodejs based. Please read https://k6.io/docs/using-k6/modules for more information. Remote resolution error: "Get "https://winston": dial tcp: lookup winston on 127.0.0.53:53: server misbehaving" at reflect.methodValueCall (native)
How do we import node modules?
