Hello there!
I am experiencing issues similar to those discussed here.
Sadly that solution does not help me.
We have a setup that basically runs 2 instances of Loki with, distributor, querier and ingester. It is modeled on the official docker compose and uses memberlist. There is one query frontend and no external caching.
The query result is inconsistent depending on which backend querier is selected.
On one querier results from the last few minutes are in the result, on the other they are missing. This also happens when querying a querier directly or when going through the loadbalancer.
To be more precise I get a different sub-set of the complete result depending on which querier is selected.
I have attached my configuration.
Could someone please point me into a direction I should investigate next?
target: all
server:
http_listen_port: 3000
grpc_listen_port: 3001
log_level: debug
http_server_read_timeout: 300s
http_server_write_timeout: 300s
http_server_idle_timeout: 120s
memberlist:
join_members:
- ${JOIN_MEMBER_URL}
dead_node_reclaim_time: 30s
gossip_to_dead_nodes_time: 15s
left_ingesters_timeout: 30s
bind_port: 7946
schema_config:
configs:
store: boltdb-shipper
object_store: s3
schema: v11
index:
prefix: loki_index_
period: 24h # Optimal size for boltdb
storage_config:
aws:
s3: ${S3_URL}
insecure: false
sse_encryption: true
boltdb_shipper:
active_index_directory: /tmp/loki_index/index
shared_store: s3
cache_location: /tmp/loki_index/boltdb-cache
index_cache_validity: 5m
chunk_store_config:
max_look_back_period: 4320h # 180 days
compactor:
working_directory: /tmp/loki_compactor
shared_store: s3
ingester:
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 2
heartbeat_timeout: 1m
num_tokens: 128
heartbeat_period: 5s
min_ready_duration: 1m
join_after: 60s
observe_period: 5s
final_sleep: 30s
chunk_retain_period: 6m
limits_config:
reject_old_samples: true
reject_old_samples_max_age: 168h
query_range:
align_queries_with_step: true
max_retries: 5
split_queries_by_interval: 15m
parallelise_shardable_queries: true
cache_results: true
results_cache:
cache:
enable_fifocache: true
fifocache:
validity: 24h
frontend:
log_queries_longer_than: 5s
downstream_url: ${DOWNSTREAM_LOKI_URL}
tail_proxy_url: ${DOWNSTREAM_LOKI_URL}
compress_responses: true
querier:
query_ingesters_within: 2h
query_timeout: 5m
