Instance group as variable
    v9.4.1 in Docker
    I have servers named AB001PRDS01, AB001PRDS02, AB002PRDS01, AB002PRDS02, … and so on. I want in the dashboard a selection for AB001, AB002 and so on and the queries are then the sum of the value over all those hosts.
    I have no idea.
  • What happened?
    Nothing yet.
    A dropdown menu where I can select a group of servers and I can then see the metrics summed up.
    Current query: sum(windows_terminal_services_local_session_count{instance=~“$farm”, session=~“active”})
    The variable $farm should be all the servers grouped together.
    No errors.
    Could not find any.
